Template Errors: PAGE_CONTAINER
  1. htmlspecialchars() expects parameter 1 to be string, array given in /scsiraid/vhosts/forum.ih8mud.com/httpdocs/internal_data/templates/S.11,L.1,PAGE_CONTAINER.php, line 12438
  1. An upgrade is pending. The site is only accessible in debug mode.
    Complete Upgrade
sanity check, should tranny output shaft be step-free?
Discussion in '40- & 55-Series Tech' started by brider, Aug 22, 2006.
  1. brider
    brider
    609
    Feb 9, 2005
    I found a replacement 4-sp tranny for my Pig, but discovered last night that there is SEVERE stepping on the splines where the t-case input gear rides. I would guess that this tranny lived for a time behind a V-8.
    Is this stepping acceptable,typical, or normal? I've installed a few trannies now, but I don't remember this kind of spline wear. Seems like you'd feel the slop going on/off throttle.
    Opinions?
  2. Poser
    Poser Oh...Durka Durka Durka. s-Moderator Supporting Vendor
    20,373
    Media:
    17
    Albums:
    1
    722
    Oct 1, 2003
    MN
    Find another one....there are pleanty of them out there in good serviceable condition yet.
    Good luck!
    -Steve
  3. GJCruiser
    GJCruiser
    260
    Jul 19, 2006
    Grand Junction, CO
    Not sure what you mean about a "step". I had above-normal wear on both output shaft and input gear. The normally thick splines were worn down to sharp points if that makes any sense. Vehicle had significant "clunk" in and out of load going down road. Above wear would allow a couple of degrees of backlash between gear and shaft. My fix was to install H41 and new input gear. HTH
  4. brider
    brider
    609
    Feb 9, 2005
    That's what I thought-
    I'll see if the guy I got it from has another with a good shaft, or see if he'll take it back.
    Thanks!
