I soon discovered my newly purchased 91 FJ80 has a leaky sunroof. No surprise after reading this forum. There is water coming in near the front passenger OS handle on the windshield frame. Again no surprise.
But here is what is wierd about it... I took the front plugs out of my rocker panel and poured a glass of water down the sunroof drainage holes. I heard water draining properly out of the rocker panel hole and on to the floor of my garage. But I also looked in the cab and saw water leaking in the same spot above the handle. The drivers side does it too, but not nearly as bad.
Its a 91 and there are no stains to indicate long or even previous water damage.
So.... If my drain is not clogged and it still leaks into the cab, what is the fix???
Thanks
Thanks
