Guys.....
Those of you who are running the Saginaw power steering boxes and pumps....... what do you hear?
First off, my steering stops on the inside and outside of the knuckles are adjusted so that the steering box can turn fully (lock-to-lock) to driver and passenger side as limited by the steering box.
When parked on concrete (Cruiser not rolling) I feel resistance in the steering and it squeals when I turn the wheels about 15 Deg. to the driver side of the straight ahead position. I also have a squeal when I turn the wheels fully to the passenger side.
If I fight the steering and work it to the fully driver side direction, I can then turn the wheel all the way from driver side to passenger side without any squeal. It will feel perfectly normal as long as I keep rotating the steering back and forth from lock to lock. Let it sit or drive it and the squeal starts up again. Also, if I park, I have the same experience of feeling resistance at 15 Deg. toward driver side and the squealing.
If the wheels are even slightly rolling, I can turn the steering from lock to lock but I have squealing at both extremes.
Another bit of info: If I place the front axle on jack stands and turn from lock-to-lock, I don't feel the steering resistance at 15 Deg. but I do hear the squeal at ends of travel. With the engine off, I can turn the wheels from lock-to-lock without feeling any resistance along the way (no binding at the mysterious 15 Deg. spot)
I'm ready to order a new steering box. I don't think it is the belt being too loose; it is as tight as I can get it and I have replaced the belt. And, there are times (as stated above) where everything seems normal without the squeal. I also replaced the fluid. Perhaps a relief valve somewhere not functioning properly??
Just wondering if you experience squeal at ends of steering travel?
Thanks.....
Thanks.....
