Saginaw Conv. Relay Rod
Montgomery Co. TEXAS
Does anyone make a heavy duty relay rod to go fromt he pitman arm to the knuckle? I've looked at sleeving the one I have but that would still leave a weak link at the ends.I've got the JT Outfitters HD tie rod and am very pleased with it. I guess I'm looking for something like that but for the relay.
Ang suggestions? What are others running?
Thanks,
Mike
San Jose CA
Not Heavy duty,
but I did insert 1/2" rod inside my relay rod, just short enough to clear the threads on both ends. I figured it would may it less prone to bend, and possibly help it hold it's shape if I had to straighten it sometime out in the boonies.
I also did the factory tie rod the same, but with 5/8" rod, and it made it a lot less prone to bending. I used to get 1-2 years out of a tie rod, and now I have several years on the one I added the internal rod to.
nuclearlemon
not an addict
Moderator
windy wyoming
i originally ran a stock tie rod that was cut in half, shortened, and welded back together using a head bolt with the head cut off as filler. worked great until i bent it just on the edge of the head bolt. then, had jack rice make me a real drag link using 80 ends to match my tie rod.
Hey Ige, I just read that in Manny's toe-in post. That's what I'm after. What's the best way to get in touch with him?
Mike
let me know if anyone replies to you question.
I am in the same boat.
My realy rod is bent over the tie rod.
I just bought the hd tie rod.
please feel free to reply to my e-mail.
valdezhome@earthlink.net.
I dont log on to this site very often.
thanks.
