Wanted Saginaw Box (1 Viewer)
landcrusher909
Athlete/Race truck driver/Hobbyist
Southern Calif.
Going with the Saginaw Power steering converson on my 1973 FJ40 just thought I would check here before heading to the junk yard. I have most of the stuff just need the Box and pump Thanks.
I have a Carquest Reman in the box..........................
Scout or Scout II correct?
it doesnt have a pitman arm
:beer:
I just bought a '72 40 for parts and it had this saginaw box with it. I don't know anything about it, but if its what you need how about $40 shipped.
After 909 has found one...Im also in the market
The one in the picture is not the one you want, look at the bolt holes. No dice my friend
Sorry to kill a sale. But saving you grief down the road
that all depends. sure, the 4 bolt boxes are stronger than the 3 bolt models but what's more important is that you want the 4.25 turn box, not the 3.5
the tire seize and how the vehicle is used will make a big difference as to which box ( 3 or 4 bolt ) you want. if the rig is tock/semi-stock and still sprung under on 33s or less, then you can get away with the 3bolt box. anything bigger than that and i'd run he 4 bolt and nothing else.
steering geometry has more to do with it than the # of bolts holding the box on.
fwiw, i can get you a decent deal on a reman box if you want one rob. i have them in stock at all times. 4 bolt, 4.25 turn.
hth
georg
