Hello Mud!
This thread is for "Safety" discussion on using 255/70R18 113T wheel/tire combination on a 2013 LX570.
I've read the (great & informative) historical threads on skinny tires like 255's discussing...
+ "Pros/Cons of handling characteristics" (on/off road, wet/dry, snow, mud, etc.)
+ "Contact Pressure vs. Contact Patch"
+ "personal preference"
+ "availability"
these threads remain currently valid still (IMHO) and doesn't need to be elaborated on again here.
I've heard outside of U.S. Market, LC200 variants came OEM with 255's for LC200's.
I've also experienced a major/corporate tire retailer refusing to mount the below tires on my LX570.
(predominant concern seemed to be conservative "Liability policy/exposure")
-----> EDIT - added below 3 lines of remembered details to be fair to retail chain <---
Shop also indicated narrow tread might have an "concerning" angle of between rim & tread... sidewalls leaning inward /_\.
I double checked manufacturer spec... Rim Width Range: 6.5-8.5", so my planned 18x8 wheels should be fine.
Also, shop said "would not touch tires" going from OEM 20" to 18" due to reduced safety when "cornering at speed".
A locally-owned tire shop is OK with mounting them, and did discuss differences of handling I will see on 255's.
My particular planned usage is :
90% on road (daily driver + long-range highway travel)
10% unpaved roads and light off-roading. No Towing.
on Stock Drive Train & Stock AHC.
Ignoring the "why" of my interest in using 255's...
Are there definitive "Safety" factors when using 255's, as long as 2013 LX570 GVWR:3345KG (7385LB) limit is observed?
=== TIRES SPECS ===
Bridgestone Dueler A/T RH-S
255/70R18 113T M+S
MAX LOAD 1150kg ( 2535 lb))
at 350 kPa (51 psi) MAX PRESS
=== WHEELS SPECS ===
18x8 JJ 60 --> OEM from a Lexus LX470 2005
+ "availability"
=== TIRES SPECS ===
255/70R18 113T M+S
