Rusty Rear Sill/Tailgate Panel Issues
Discussion in '40- & 55-Series Tech' started by Felix, Jul 8, 2005.
  1. Felix
    Felix
    2,354
    527
    Jan 15, 2005
    Alexandria, VA
    I just bought the CCOT tailgate panel with the ear tabs that attach where the lower hinges for the rear doors were, but I can't get the holes to line up right. The problem is that because of some rust, the rear sill is has raised by about a 1/4 inch on the far right and left side. Because this panel has a lip all the way along the bottom, this pushes the whole panel up enough to screw with the fitment. What's the best way to correct this in the short term?
    I know the right answer is to address the rust and replace the rear sill, and I will eventually. I just want an easy fix until then. Do I try to pound on the lip to bend it up so that it follows the contours of the warped sill? Try to remove a little bit of the rusted sill material?
    Maybe it will stop raining this afternoon so I can get some pics.
    Thanks,
    Felix
  2. Pinion
    Pinion
    1,124
    1
    Jun 16, 2003
    Milford, Mass
    BFH.
    Pound the sill down. No worries if you are going to replace it anyways.
  3. Felix
    Felix
    2,354
    527
    Jan 15, 2005
    Alexandria, VA
    Sounds like a good plan, thanks.
