Runs fine, but what are those sounds???
Washington State
Website
www.youtube.com
I hope I can explain this properly, but when you’re dealing with sounds, everyone might hear something a little different. I recently had a new clutch put in, as well as pilot bearing, throw out bearing, clutch plate, rear main…all the things you might as well take care of while you’re in there. A little while after it was done I started to notice two noises. One is sort of a faint chirping sound that would come and go. When I could hear it, a very slight touch to the clutch pedal would make it stop. Of course, it wouldn’t do it when I took it back to my mechanic. The other noise sounds like maybe something is loose when it’s not in gear, push in the clutch pedal and it stops, let it out and it comes back. This noise seems to be more prevalent when the rig is well warmed up and has been driven for a while. Again, that noise didn’t happen at the time I took it back to the mechanic either.
I took the family camping this weekend and a new noise popped up. A sort of vibration/rattling noise that happens when the rig has been sitting say overnight. Start the engine up in the morning, let it warm up a bit and it happens when you take off in first gear and sounds like it’s coming from under the truck. Once the truck is warmed up, it doesn’t happen anymore. The chirping noise also seems to be getting louder and not so intermittent. I’ve repeatedly checked all the fluids and checked to see if I can find anything loose under the truck but so far, everything seems to be as it should. The engine is still running smooth and like a champ. The transmission doesn’t slip or jump out of gear. Other than getting annoying and making me worry a bit, the truck is running fine. I’m going to run by my guys shop again today but I wanted to see what the Mudder group thought.
Any ideas would be greatly appreciated.
Thanks,
William
... One is sort of a faint chirping sound that would come and go. When I could hear it, a very slight touch to the clutch pedal would make it stop...
That sounds like the throw out bearing. Usually an old one will start doing this. Since you had a new one put in, maybe give it a while and see if it will get quieter?
... The other noise sounds like maybe something is loose when it’s not in gear, push in the clutch pedal and it stops, let it out and it comes back. This noise seems to be more prevalent when the rig is well warmed up and has been driven for a while...
Is it real faint? In neutral, my sounds slightly different clutch in vs. clutch out. It could be normal noise.
You might also check and make sure that the shifter boots are bolted directly to the metal, instead of bolted with the carpet sandwiched between. It will let a little bit of noise through, and old noises will sound like new...
Good luck, I hate hearing new noises after putting in new parts.
:beer:
I hope I can explain this properly, but when you’re dealing with sounds, everyone might hear something a little different. I recently had a new clutch put in... throw out bearing... COLOR]
Thanks,
William
Are you sure they actually replaced it and didn't just tell you they did? This sounds like classic T/O bearing faliure. Or, maybe they used cheap chinese shiz the fell apart in a few thousand miles.
Good luck, but I don't think you're going to like how this turns out...
The parts I ordered from Cruiser Dan. So far my experience with this place has been good as far as working on my other vehicles so I can't say that I think they're trying to screw me. I let them work on my cruiser since they have an old school Toyota tech there who could tell me about my rig and seemed to know what he was talking about. At this point I have to assume they did the work (forgetting that whole saying about the word "ass-u-me").
If the clips are worn on the release fork, could it make such a (chirping) noise?
If the input, output, or center bearings on the shaft are getting worn, could they possibly cause that loose sounding rattle noise when the clutch is not enguaged?
Thanks,
William
:beer:
Me Too!:bang:
No, it's starting to get fairly loud. When I got home today, I parked my rig and left it running in nuetral, got out and stood there listening to it then looked underneath it. I could easily hear it outside the vehicle. Got back in, pushed in the clutch and it stops.
I don't think I like where this might go...:bang:
Well, I own a cruiser so I'll man-up and do what I need to do....after I figure it out.
William
If all is adjusted properly I don't believe the throw out bearing should be spinning when the vehicle is just sitting there idling. It could also be the pilot bearing as these thing are often very difficult to get out, and then they must be driven in properly. Anyway this is the case on most vehicles. I have to admit I have yet to replace the clutch on my land cruiser. Usually a chirping sound indicates a bearing failure. They chirp and eventually die and blow apart. This could be why a vibration is presenting itself. I am not an expert but I thought I would give my input. I hope it helps.
rdo
I'm not a clutch expert, but here is a suggestion. Check the gap between the throw out bearing and the release forks. Maybe the forks are just clipping the throw out bearing and creating the "click". Should be about a .21 gap.
My $.02
Jerry D.
