Hi all, I'm trying to run a wire thru the roof in the same manner that @savirc did in this post:
Below are the picture of what I have to work with. I'm thinking If I drill out that sealant (and maybe a little further) I should be able to get wires for my solar thru in the general vicinity of the oh s*** bar in the reat passenger seat - I already have good sealent to block up the hole again when I'm done.
What I could use some help with is how to get the interior roof of the car away the vehicle far enough that I can drill/insert/fish the wires thru, so that I can run them down the B pillar to my dometic battery. Clearly I need to remove the oh s*** bar (which looks easy...judging my the missing plastic piece it is just screwed on). Once that is off will i just be able to wedge a trim remover in somewhere to pry open an area to work in under the roof, or is it a lot more painful than that?
Running wires through the firewall
Hey everyone. I've tried searching with no real definitive answer. How is everyone running wires through their firewall for lights, accessories, etc. I anticipate having to run at least 10, 16gauge wires through my wall for roof lights and a switch panel I'm making. Do you guys holesaw the...
forum.ih8mud.com
