Running hot after headgasket- give me ideas
Socal
HG was PM'd, not blown.
Before- 184F-190F mostly. (It would quickly drop from 190 to 186 if I just let off the gas on the freeway for example) Long grades it would go above 200F but come down quickly.
After HG 190F-200F mostly and stays around 200F and easily goes to 203+F just from normal use and does not come down below 193-ish.
*on a typical short fwy grade I hit 213F where as before it would be only 195F or so.
I have a SG and see the temps constantly so there are no other factors.
No other changes.
Typical stuff has all been PM'd-
-fan clutch, plugs/wires/cap/rotor, tstat, belts, hoses, no leaks, fresh oil/coolant obviously
-radiator is good - same before and after.
what else should I look for? I am stumped.
I installed my Scanguage only after the HG. I don't know what the temps were before.
My readings are about the same. Never below 193ish.
I'm driving up to Lake Arrowhead on Tuesday morning and I'll check the temps going up that hill.
The first thing I would do is make sure the coolant is full. Dont just check the rad. There could be a airlock in the system. Check from the heater valve in the firewall. Fill it from the engine side (the us drivers side) until it wont take anymore.
that'll teach ya to fix what ain't broke
:rolleyes:
:D
seriously though...aside from checking for possible air bubbles in the system as already suggested, I'm not sure what else to suggest...
:hhmm:
What you describe is what i used to have before i did all of the cooling system rebuild. I had a scangauge show around town temps of 204 and as high as 216. I first changed the fan clutch, new blue from CDan, this dropped temp to around 198 around town. Then replaced radiator with older brass style, thermostat, hoses, new phh (yellow silicon hose same as phh), most parts sourced from CDan as well. My temp are now running around 184-186. I have not had the headgasket done to my knowledge. I may check at the local lexus dealer to confirm that this was never done there as well.
Only thing i can think of that might cause something is the thermostat not installed correctly?
Jon.
Tough problem James.
If the HG PM is the only variable then you have to assume something changed during the R&R.
* Timing could affect the temps.
* Another thing to check would be the belt tension.
* As others have suggested, coolant. (bubbles, level, themostat position, etc.)
* I hate to suggest it but what about the oil cooler
... did you have any oil cooler issues or anything like the pics that Ruadrigh posted a few months ago when he did his HG?
HTH and let us know what you find. Hopefully it will be something simple like the timing or the belts.
-B-
Thanks for the replies.
The only thing I didn't check or is applicable is the heater air bubble thing- can you describe where I should look or fill coolant? Do you mean the hoses known as the "FHH" at the top/rear of engine? a heater hose and phh was replaced during the hg.
no oil cooler issues, truck ran fine before.
And, it could be normal. The new head gasket routes the coolant differently than the old one. The temp sensor is in the head and so even small local changes in the flow could affect the readings.
Why not try a long uphill grade and see if the temp finds a level and stays there. That's probably the highest temp it will reach in use, and if it's less than spec, you're good.
Other factors is the coolant sensors are all now clean of any deposits, Yes the flow through the head has changed(did not think of this). Head is milled .010 to clean the surface. All carbon was cleaned off the pistons and cylinder walls, Timing set at 6 deg BTC instead of stock(most 1fz's run real good with this). Thermostat was not changed, blue fan clutch was on before and the radiator was not removed for cleaning. But all thing considering Toyota book specs for normal is 190 to 203 deg F. Where the t-stat is fully open at 210 deg F.
It would be interesting to see how the other 5 trucks are running that were just done at the same time with almost the same parts. James, does any one else have a Scan guage? Have you driven up to the mountains to see if it goes too hot. Right now our engine is somewhat normal according to Toyota. Spikes in temps are one reason Toyota did what they did to the Temp gauge. A normal engine spikes until the cooling system can adjust to the heat and cool the engine. I will be back next week and if needed can explore this futher with you.
Catch you later Robbie
Nice Robbie. :beer:
You guys need to stop looking at Scangauges and start driving your rigs.
Since Robbie did the work, I would be hard pressed to find anything wrong and to accept the new temps are operational normalcy.
going up the 330/30 is a great test, i'll be curious how it goes thanks
I'm up at Lake Arrowhead now. Temps never went up above 212 degrees on the drive up the grade to the top of the mountain.
On the highway, it did not go over 200.
My HG was done at the same time by Robbie. During the HG PM I had the blue fan clutch installed, PHH, and new water pump.
James, I didn't pay attention to the differences in HG either. I have similar results and I wonder if Andy's hypothesis is correct...
