Hi Everyone,
I am struggling to sort through my 12v system and accessories. I have my switches mounted to the ceiling center console, however the run (overall length of low volt wire is too far to run from my main battery. Here are the components I want to run off my main battery:
1) Flood/Long Distance Driving Spots
2) Fog Lights 6" LED x2
3) Fog Light 21" LED x1
4) ARB Air Compressor/Front and Rear Air Lockers
The remaining accessories I will run off my second battery
1) Inverter
2) Rear Hatch LED x2
3) Ext. Camping Lights/Off-roading Lights
4) RTT Power
5) Random Device Chargers throughout the vehicle
I want to run all of the accessories low volt through the passenger firewall (its where I have done it in the past) and up the pillar to the ceiling or to the center console by the shifter.
The rub is that I am using quick connect compatible connections, which allows for a pretty easy install and uninstall (flexibility) but the running length of the wire from the relay to the switch is quite short.
In a perfect world, I would set up an accessory tray that mounts to the firewall and have positive/negative terminals there. I am struggling though because I am an electrical novice.
I have relays and in-line fuses, so I am thinking of an easy solution like this: 12V Distribution Block
I'd love to see images of installations from other people on here so I can wrap my mind around the scope and the DIY instructions before I dive in, because I've found good prep/plan eliminates so much wasted time ... which I can't afford as a Dad of two when working overnight.
1) Inverter
4) RTT Power
