I have tried searching but I am wondering if any of you can help me diagnose a vibration I am getting through the seat of my pants as I move off from a standing start (very scientific description eh!).
It sort of feels like really baddly scalloped tire(s), but goes away as soon as the vehicle is moving about 5 or 10 mph.
It doesn't make a lot of difference if I'm in 2wd or 4wd, although it does seem to be a little better in 4wd and does not seem to do it in low range as much, if at all. The fact that I'm feeling it through the seat, and that its worse in 2wd, makes me think its comming from the rear end somewhere.
All I have been able to find by searching is the rear tailshaft might need some work. Mine doesn't seem to have any slop in it at the unis, but I do have a new one to put in as the splines on the old one are worn a bit but not enough (I don't think?!?) to be causing this. Could a worn uni joint be causing this sort of thing without any obvious movement or slop? I would expect to be able to get some play be turning the shaft while lying under the car.
I'm kind of wondering what symptoms I would get from a failing diff, as I have only ever had them go BANG in very spectacular fashion on the trail!! Any help would be much appreciated. In the meantime I'll go and put this new tailshaft in and see if it helps.
FWIW I'm running BFG MT 33's which are not scalloped, and about as well ballanced as MTs get!
TIA Scott
TIA Scott
