Though it's advertised as usable on the 9.5" dif it seems to be a bit of a compromise. Without a doubt it will require some pretty heavy beat and beat treatment. More of a problem than that is placement and that's where I'd like some input.
Basically there are 2 choices. 1. line up the bottom edge of the guard with the bottom of the "bowl."
In this position a hard hit would have the guard supported well and keep it from collapsing the "bowl". But it leaves the protruding area just below the fill hole unprotected as you can see here:
The second would be to raise it up a bit fully protecting the bowl bit leaving a large gap at the bottom.
I bought 2 of these things and want to use them but it pretty clear that they are almost as much work to fit as it would have been to get some 5/16 plate and cut and bend it. Bummer as I carried these all the way to Japan on hopes of saving the labor. And now I really don't have time to start from scratch....
Pete
Pete
