Rubber/Plastic Plug Part Number
AZ
Missing one of these for second row. Cannot find anywhere - does anyone know the part number?
Don't spend too much for OEM. You can get assortments cheap. Here's one that's got 50 for less than 12 bucks.
Amazon product ASIN B00PP7XU1E
Those won’t fit. The hole isn’t round and needs special tabs in an arrangement to hold.
I’ll try to remember to look up the part number when I get home.. but exactly which part do you need @c4xplsv ? Send an overview pic including the missing location. There are three different part numbers if I remember correctly.. probably 2 or 3 times that many depending on color actually.
I’ll grab a pic when I get back.
Paul
Looks like it should be 72329-60090-C0 and with the C0 being your color code, black.
The two middle are the same.. so you could lift the other like one and see whether it has a number on it. IIRC the correct method to pull them without tearing the rubber tabs is to push toward the center and lift from the front straight edge, where the dip in the trim meets the round cover. A tab sits on the straight edge and when you get that to release the rest will lift without ripping the rubber catches. Mine are all torn from not doing it correctly at first.
