Get the air cleaner/carb gasket at Toyota.
The other big failure with these (after flat out missing) is improper installation.
The gasket snaps into the opening of the aircleaner. It does not just lay on the carb, like the earlier models.
Jeeze, I been doin this wrong from the get-goThe other big failure with these (after flat out missing) is improper installation.
Thanks. Mine no longer snaps well to the air cleaner after being installed wrong too many times.The gasket is Toyota part # 17848-61020
The gasket gets oily, prolly from vapor coming into the aircleaner via the valve cover vent hose.
speaking of that hose.. does it require a clamp on both sides. only the air filter side of mine is clamped, the valve cover side is just slip fit..
Useless wire spring clamps were installed when new.speaking of that hose.. does it require a clamp on both sides. only the air filter side of mine is clamped, the valve cover side is just slip fit..
rubber gasket between carb and filter body... mine was missing for years, I replaced it today and it made a big difference. my vacum gauge reads higher and the intermitant bucking toned down a lot.![]()
