NaterGator
On Gilligan's Island
Ok I'm at a loss.
I'm trying to set my driver side wheel bearing preload and it isn't going completely according to plan. First when I gronked down the locking nut to torque spec it sheared the indexing tab on the lock washer.
So I had to go buy more... no big deal. Now I'm noticing though that when I torque the adjusting nut to 41lb-ft (or whatever the FSM spec is, don't have it handy) the second time and then go to loosen it until free by hand, there is a loud clang that comes from the hub.
If I stop, and then start loosening again the clang happens again... it sounds like something shifting but wtf it is I have no idea and my passenger side didn't do this when I was setting it. I proceeded ahead and tried to set the adj nut to 48in-lb and put the locking nut on, but the lock washer index got a bit mangled again.
I also noticed that my fish scale is reading about 13lbs even if I set the adjusting nut a bit loose.
So a) any ideas wtf the noise is, and should it be giving me pause?
B) Is it normal for the lock washer index to get a little deformed when torquing the lock nut to spec, and should I be concerned that my fish scale is showing me about 2lbs higher than FSM spec?
This is driving me crazy and I've got a break in the weather to button it up now. I need to get this thing freaking set
