A little stumped here. Completed a bunch of maintenance on my 97, got it all buttoned up last night, and won't start. Cranks fine just doesn't fire. I imagine it has something to do with the work I just did, most are unrelated to the ignition but here's the list in case something might be relevant:
Compression test (unplugged distributor/spark plug wire from power to crank, started with the pedal to floor to put it in flood mode)
Valve cover/spark plug gaskets
New spark plugs
New wires
Removed air tube and throttle body (Sprayed throttle body cleaner into intake tube and throttle body, new TB gasket)
Replaced most vacuum lines that I could easily get to (Could a wrongly routed or slightly too short line cause no start?)
Tie rod ends (Front steering went back and forth multiple times without key in and locked the anti theft steering more than once during the job, is there some kind of antitheft immobilizer?)
U joints ( Could turning driveshafts trigger some kind of neutral lock-out safety thing?)
Rear brakes
The battery was fine as it cranks strong I jumped it to be sure.
Left battery unplugged to clear ECU
CEL is on when cranking. My HF scanner indicates no codes though?
Confirmed that there is spark. Pulled out plug, connected to wire and grounded plug to neg. and cranked.
Plug smelled like fuel so looks like it is getting fuel and spark?
Has VIP alarm system
I will add anything else I can think of.
New spark plugs
New wires
Rear brakes
