The TC fill plug in my 83 FJ60 will not come off and now the head is stripped, I am going to apply heat with a torch but want to make sure the heat will not damage aluminum tc cover?
I've applied heat there. Don't be too aggressive with it.The TC fill plug in my 83 FJ60 will not come off and now the head is stripped, I am going to apply heat with a torch but want to make sure the heat will not damage aluminum tc cover?
If it is stripped, how do you plan to remove it after torching it?
thanks! I was thinking vise-grips
Like Seth said, penetrsting oil, heat, penetrating oil after heat.
If vice grips fail, I would drill it and use an ez-out.
That's a good idea.If you get to the drilling out stage of the game you might consider using left hand drill bits...they drill in the direction of loosening the bolt so that you have a chance that the drill could become the easy out
Here’s my fill plug, prevents stripping
Better the fill plug than the drain plug.
