Hey guys, need some advice here. Sorry for the longish post, just wanted to try and give as much info about the rig as I know.
Purchased a 1976 FJ40 a few months ago. Least rusty one I could find in my budget. Had a bunch of work done on it already (new OME suspension, electronic ignition, new seats/console, new tires etc.), but ran a little rough. Figured it should be easy to sort out so made the purchase. Not a lot of history about the rig other than the little I got from PO. I think it went from stock 76 2F to SBC (sigh) and then to the 79 2F.
First thing to sort out was the cooling which I have fixed (new radiator, WP, hoses etc.)
Next was to tackle the rough running 2F. It's a 1976 but has a newer 2F in it. Best I can tell from serial # (2F343733) is early 1979. It has Toyota power steering.
Came with a Weber and a Electronic Distributor (HEi unit from MAF i believe). First thing I did was order a new carb from Trollhole. Finally got that in and replaced the carburetor. Had to un-weberize the linkage a stuff, but it was all there. Stock parts fortunately in the parts box from PO. THC had a weird spot in the casting and seemed like it was cracked clear through. Not sure if it is, but let Marshall know and he put a new one in the mail.
While waiting, I installed the THC anyway. Still had to fix a bunch of stuff to get the new carb set up so at least I could get all of the lines and linkages sorted out.
Still ran rough with THC on and I noticed it only pulled 5-6 inches of vacuum. Not surprising since it had a bad exhaust leak as well. Crap, time to pull the manifolds and replace gaskets. Ordered a set of Remflex gaskets and a EGR port block plate from Mark. Bolts stripped out at EGR port and leaking badly. I'm guessing that the new gaskets should take care of the exhaust leak as well as the vacuum leak.
Gaskets and EGR plate arrive and I pull the manifolds. Not as bad as I was expecting...no broken bolts or anything. Good.
I can see from carbon buildup that exhaust manifold was leaking as well as EGR port. Manifolds look to be in good shape with no cracks. Should be an easy fix me thinks.
Get manifolds back on, Remflex seems to snug up really well. I decide to torque to 30 lbs which is right between Remflex recommendations and stock torque. I also got the new carb from Marshall and put that on as well. Fixed broken bolt on EGR port and installed plate and gasket. Things are looking good! Pulled the EGR cooler and associated lines as well. Much tidier now!
Go to start up the rig and it's hard starting. I crank until I see gas in the sight window and pump it a few times and it finally fires, but runs really badly. Worse than before. My exhaust leak seems fixed but I still only pull 5 inches of vacuum???? Will barely run. So I pull the new THC off and put the original THC one back on. It runs much better, but still only have 5 inches of vacuum. I can get it to idle, although it is rough, and I can drive it...but lacks power.
I've plugged up every vacuum port that I can find after the half assed desmog, but I must have missed something?
I also notice that there is raw fuel in the intake manifold. I noticed some when I pulled the carb off before, but also noticed it leak out when I pulled the vacuum meter off of the port on carb base plate.
I have timing ballparked close to 7 degrees, but since it doesn't idle to well I figured I would dial that in after fixing vacuum leak.
As I mentioned above it has electronic ignition with mechanical advance.
Any ideas where I could have missed a vacuum port? I have replaced all vacuum lines. I only have two really. PVC to intake and brake booster to intake. All ports on carb are plugged. I have the EGR line that used to go to EGR cooler plugged off.
Haven't re-torqued the manifold bolts, but at only 5 inches seems like it is something else. Thoughts?
I will post up a few pictures of the setup to see if that helps identify anything.
