Previously I had an issue with truck hesitating on take off. At that point I had a manifold vacuum reading of 17 ish. I replaced all the vacuum line and that seemed to resolve the issue.
Its a 3/79 2F with cali smog that appears to be complete.
So I drove it for a few days and it ran fine. Now, though, it idles rough and only has a vacuum reading of 5. I assume this is my issue but I don't know where to start. I took the reading at the manifold were it connects to the carb via 12 rubber hose (near the top of the bowl). When I pulled the hose the idle kick up but still ran rough.
Fuel in the bowl looks good. I can see fuel running through the filter. I have pulled one plug wire at a time and it doesn't seem to have an effect. Will run fine under load or without. Pulling the choke out improves and increases idle as I think it should.
Hot or cold engine does not make a difference. Also, sprayed carb cleaner around the carb and manifold did not detect and vacuum leaks or at least no increase in idle.
Whats my next move? Thanks
