Rough High Idle
Cape Town, South Africa
Om my FZJ80 (Aussie spec), I notice a rough idle when the air-con kicks in - this picks the revs up to about 1000rpm. At first I thought it may be the air-con pump, but if I bring up the revs to this point without air-con, the roughness is still there. Listening and feeling exhaust pulses, it does not seem to be a misfire. Any ideas?
I must add that my fuel pump is at an end as there is low power below about 2800 rpm but after that it takes off like a rocket (OK, a very heavy rocket). Bypassing the fuel pump resistor fixes this problem but not the rough high idle
There is no other roughness or missfire at any revs
I have replaced the fuel pump so that issue is sorted but the rough high idle is still there. Also, under hard acceleration it seems to hiccup. Very slight but it's there.
Where do I start?
