ROTW: Moonshine
Discussion in 'HardCore Corner' started by GLTHFJ60, Sep 30, 2007.
  1. GLTHFJ60
    GLTHFJ60 Rum Runnin' SILVER Star
    22,330
    6,085
    Apr 18, 2005
    Durham, NC
    Yup:
    Wiring an 8274 + Albright
  2. GLTHFJ60
    22,330
    6,085
    Apr 18, 2005
    Durham, NC
    Pulled the radiator out of Moonshine to force myself to install an intercooler (finally):
    [​IMG]
    [​IMG]
    Hoping to get to this project this week:
    [​IMG]
    Shouldn't have been shopping, but due to the dryrot of my swampers, and the hole I put in the sidewall of one at GSMTR this year, I jumped on a set of used 42s that were a good deal.
    42s next to my old 39.5s. Neither tire has a rim in this shot:
    [​IMG]
    [​IMG]
    [​IMG]
  3. cruisermatt
    cruisermatt ランドクル62! SILVER Star
    5,207
    Media:
    11
    Albums:
    2
    1,827
    Jul 22, 2012
    Orlando Florida
    Why do you need and intercooler and bigger tires? Where can't you go now that you need more (safe) power and bigger tires?
    :flipoff2:
    CenTXFJ60 and GLTHFJ60 like this.
  4. GLTHFJ60
    22,330
    6,085
    Apr 18, 2005
    Durham, NC
  5. woytovich
    woytovich Fake news SILVER Star
    11,427
    Media:
    2
    Albums:
    1
    922
    Sep 2, 2003
    Metro NY
    Asked and answered a few posts back: "because"
    GLTHFJ60 likes this.
  6. The Phoenician
    The Phoenician F*ck your sensitivity!
    3,351
    Media:
    7
    Albums:
    1
    1,319
    Jul 27, 2011
    Texas/Iraq/Lebanon/Yemen/Liberia/Syria
    Johnny, what size intercooler are you able to fit? I'm thinking I might go larger when I get back.
  7. GLTHFJ60
    22,330
    6,085
    Apr 18, 2005
    Durham, NC
    It's a powerstroke intercooler out of a van I think. Gonna be a tight fit, but I think it'll work. It's larger than the opening in the core support, so the opening will be enlarged.
  8. Wrench
    Wrench One Bashed Up 80
    4,606
    325
    Mar 27, 2003
    You gonna groove them?
  9. GLTHFJ60
    22,330
    6,085
    Apr 18, 2005
    Durham, NC
    I plan to groove the ones that have less tread and run them on the rear. Thinking that I'll leave the others untouched for now.
  10. GLTHFJ60
    22,330
    6,085
    Apr 18, 2005
    Durham, NC
    Mounted the 42s tonight. It's a lot of work.
    [​IMG]
    One had this inside the tire. Thought it was interesting:
    [​IMG]
    GW Nugget and The Phoenician like this.
  11. GLTHFJ60
    22,330
    6,085
    Apr 18, 2005
    Durham, NC
    Thought I would document the process to mount tires on H1 rims for next time so I don't have to spend 3x as long on the first tire figuring it out again. This does not cover cleaning the tire seating surfaces, or o-ring, so make sure you do that before starting with this procedure.
    Step 1: Grab two chunks of 6x6 and put them on the ground.
    [​IMG]
    Step 2: Put the tire on the chunks (opposite sides) then place the PVC insert on top. Lubricate with soapy water:
    [​IMG]
    [​IMG]
    Step 3: Place chunk of 4x4 inside tire on one side and bear down on the PVC insert while prying the bead up till the PVC insert is inside. Pound the PVC insert with a deadblow to rotate it:
    [​IMG]
    [​IMG]
    [​IMG]
    ##Note the carved out part of the PVC insert.
    Step 4: Place inside of rim on chunk of 6x6. Lean tire and PVC insert on your legs, over the inside of the rim, so you can align the carved out part of the insert inbetween any two studs.
    [​IMG]
    [​IMG]
    Seated:
    [​IMG]
    Step 5: Outer half of rim valve stem aligns with the carved section of PVC insert. The carved out section allows air from the valve stem to enter the tire cavity.
    [​IMG]
    The Phoenician likes this.
  12. GLTHFJ60
    22,330
    6,085
    Apr 18, 2005
    Durham, NC
    Step 6: Install all nuts by hand and pound them home with an impact. Note the gap between the upper half and lower half of the rim. Tighten the outer half of the rim evenly so the tire and insert seat properly. Start:
    [​IMG]
    End:
    [​IMG]
    Step 7: Put 10psi of air into the tire and check for leaks.
    [​IMG]
    Step 8: Torque all nuts, in a star pattern, to ~100ft/lbs.
    [​IMG]
    Step 9. Repeat steps 1-8 at least 3 more times and you get a set of mounted tires:
    [​IMG]
    Hope this helps someone, someday.
    :cheers:
  13. cruisermatt
    5,207
    Media:
    11
    Albums:
    2
    1,827
    Jul 22, 2012
    Orlando Florida
    That does not look like fun at all. I have trouble moving around 35" tires :eek:
  14. The Phoenician
    3,351
    Media:
    7
    Albums:
    1
    1,319
    Jul 27, 2011
    Looks like we have the same wheels. What's the maximum psi you're comfortable putting in the tires with those wheels?
  15. GLTHFJ60
    22,330
    6,085
    Apr 18, 2005
    Durham, NC
    I never put more than 25psi in these, but that's because I don't run them on the street. 99.99% of the time they see between 0 and 6 PSI.
  16. White Stripe
    White Stripe
    5,157
    3,268
    Jan 6, 2012
    Nice job. That is a lot of back breaking work!
  17. The Phoenician
    3,351
    Media:
    7
    Albums:
    1
    1,319
    Jul 27, 2011
    I'm only asking because if i remember correctly, you can only go up to 30 psi on those wheels.
  18. woytovich
    11,427
    Media:
    2
    Albums:
    1
    922
    Sep 2, 2003
    Metro NY
    Hutchinson beadlocks or homebrew?
  19. GLTHFJ60
    22,330
    6,085
    Apr 18, 2005
    Durham, NC
  20. Mr Cimarron
    Mr Cimarron DRIVE, BREAK, FIX, REPEAT SILVER Star
    3,637
    2,043
    Nov 8, 2011
    Austin, TX
    My back hurts just looking at those tires and rims.
    jrmudder84 and GLTHFJ60 like this.
