So I did a quick search, I've read over Woody's rebuild and hub loss thread, along with my own experience... What is the consensus on the backing plate on an 80, needed or not needed. Right now I'm not running them, but after my rebuild, the pass side, the side I didn't have come apart at high speed is now acting funny. Now I should mention on the rebuild I did upgrade to DBA's both sides so the hubs have been off. At first I thought it was wheel bearing needing to be torque back down, but when I did that I still had the play. When I looked closer I found the spindle bolts were loose. A quick re-torque on those bad boys to the 34lbs, no shield and back together with no play...
Now the question, is that spacer really needed on the 80? I know mini truck guys need spacers cause the spindle is diff with a collar, but ours are flat... So if I have everything torqued down correctly this shouldn't walk back off again right???
Thanks,
-Ammo
Thanks,
-Ammo
