i seriously need help on this...can an old school metal roof as attached to the rim/upper body hold up to lifting off the top to run without it?
i am thinking of attaching the roof rack with say...16 #10 bolts through the roof and then using the roof rack to lift off the top on trips where it is not needed.
will this work? is the question. i have a fj40-1/69.
so procedure is, drive up to 4x4 place, make camp, unbolt top and use roof rack to pull it off, assuming there is a tree or object tall enough to do the trick, and run 4x4 for a while, then lift top up and reinstall it for the ride home...
