Build Rocklander 77-series build
Impressive what were the numbers ?
It is using the full travel of the front shocks which are 10” shocks. It’s perfect as far as how much the front leaves travel and the shock travel to match that. We need to carve up the front wheel wells but not a ton. With 10” shocks I am getting over 14” of travel at the wheels! The limiting factor in the front is simply leaf spring length and how much they will move through compression and droop.
Rear will use the full travel of a 12” shock and we don’t have to mount the shock on the axle side real low. Rear needs very little wheel well cut out at full stuff for the 38’s.
Tie rod contacts frame rail at full stuff on LHS, easy, we just notch and box in the frame to allow for full compression. I cut some out of the frame this morning under the steering box and pitman arm, I got to cut a little more and then it clears full lock to lock on the pitman arm.
Bump stops are no worries all the way around. I don’t need limiting straps anywhere as the leaves limit droop.
That is what the numbers are mathing and the mathing is good!
Cheers
Cheers
What I was wondering is how hi are you able to lift the tire with the fork lift ;)
Ah! Haha!
Under the front tire 2ft 6” and under the rear a little over 3ft. It’s very stable in the pictures, it’s right at the limits of lifting a tire. However it is like I say very stable and doesn’t feel tippy trying to leverage the Cruiser at max flex, ie push it over!
Obviously as mentioned up to this point I have never done these leaf sliders before. Done lots of SoA but these are a first. It works surprisingly well! They are supposed to cause-provide constant spring rate through the travel. They definitely seem to keep the axle and tire planted on the ground with fairly firm pressure right up to tire lifting.
Cheers
That’s nice! Just dropped it earlier off the fork lift, pushed it in the shop and what do ya know!
Cheers
Nice, well done
Your work and attention to detail always impresses me Ian. I’ve been binge reading as I hadn’t seen this thread yet. When you mentioned slip springs I had a completely different picture in mind. In Southern Africa, a lot of caravan manufacturers use them instead of leaves with shackles in the rear. The rear of the spring simply slips forward and backwards along the chassis, along with a small welded box to keep it from falling out of its track. It’s not nearly as nice as what you’ve done. I remember the days of the revolver shackle, and all the ways people where trying to get their SOA’d vehicles to flex more, and a lot of them seemed great for rock crawling, but super sketchy for daily use. I’ve never seen nor heard of the slider box until this thread. How long do you expect the white nylon sliders in the box to last? What are they made of? Once again, great to see the work. Wish I could hook you up with LHD cruiser parts from Angola. As far as LHD cruisers are concerned, It’s not the Middle East, but we have loads, just unfortunate that most of the owners or drivers have no mechanical sympathy.
Lowering rear ride height, cut the leaf hanger off the frame. About to cut more off!!
Cheers
Needs to get moved forward a lot and up a bit, I will french it up into the frame rail.
I will also build a skid-ramp as needed on the front side.
Cheers
I cut a big notch into the frame! Boxed it back in with 3/16’s.
There will be more structural work before I am done to keep the frame strong here. The point is to fit this leaf hanger and to also raise this point in the leaves.
Cheers
Alrighty, got the leaf hangers squared up and tacked in place. Wheels on it and back on it’s weight.
It is a little lower, about 1.5”. I can’t get it any lower in the rear without adjusting my leaf pack which I will do and play with. My target rake degree is 1, I am at 1.3* so fairly close to what I want. I will box the leaf hanger all in and build the ramp-skid at the front then call it a done deal. It will certainly be a nice transition from belly skid to leaf skid here in the rear for dragging the ass up over rocks.
Cheers
Oh ya, my custom plates!
I really only need to drop the rear 1” to hit my target rake. Weight alone may do that, probably should toss 200lbs or more in the back and check it again.
Cheers
Chillin’ here in the shop having a beer after a long day and a hard 3hr after work session on the Cruiser.
It’s really not a bad rake where it is I just can’t stand stink bug on a Cruiser so 1* is where I like them. I took some measurements a few minutes ago; 24” under the belly, 27” under the rockers, the Cruiser is a touch over 7ft tall. Could get the whole truck lower with real flat leaves but then I will have to cut A LOT of sheet metal out. I don’t really wanna do that, got to cut some anyways but cutting out a bunch will change the look of the body a lot. My KMC beadlocks have 3.5” of backspacing, could easily go to 4-5” of backspacing but as it is the width to height ratio is great. I am 6.25” of poke outside wheel wells all around, that makes it really stable for the height.
I am just going to keep going with it and how it is playing out, if I don’t like it once I take it rock crawling I will see about changing it then. I doubt I will dislike it though, I think it will be pretty mean for what it is and how I have designed-set it up.
Time for a shower, dinner and bed! I am beat! 😑
Cheers
Cleaning my fab bay so it’s outside!
Man I like it, a lot! 😍🤙
I also bought (unless he backs out) a rolling 80-series chassis for my 79-series pickup. So I am not putting that body on this chassis! 😝
Cheers
Back in 2006 we built this, by 2009 it was as seen here. 1983 Nissan Patrol from Germany was the base for the build that I had paid $2500! It went through a few phases but in the end it’s specs were;
-Turbo diesel
-Portal-Tek portal axles, ARB lockers and much much more
-16” Ballistic coil overs
-2” 7075 aluminum links, not many were using 7075 2” links back then, massive 2” ends
-3-link front & triangulated 4-link rear
-High-9 diff 3rd members for high pinion diffs
-full hydro PCS steering, orbital valve adapted to stock column, ect.
-40” Maxxis Creepies on Walker Evan’s beadlocks
-cutting brakes on rear axle
-Wilwood 4-piston calipers and big rotors all around, rear had x2 sets of calipers for the cutting brakes.
I have better pics and even videos of it in action back in the day. I took it twice down to Arizona for a week long off-roading event with the Nissan crowd. On the second trip there was a guy (he is here on mud still!) who brought his 4-Runner that was on 42” IROKs, SoA, x2 tcases, ect. Your typical mini-truck style build. He could easily keep up with me if not out wheel me! It kind beat up my ego! Hahaha
Anyways, since then I have really wanted to build a “mini-truck” style rock crawler. That is exactly what we are doing here with the Rocklander!
I am friggin’ loving this build for this reason, simple but very capable style of rock crawler. I am not breaking the bank here with a $100k rock crawler that has to be trailer to the trails. That is what the Patrol evolved into, a trailer queen!
If you look at what I have going here, really look at the profile pics. Well, this thing has way better clearances in terms of no links hanging low, no massive coil overs through the hood or rear wheel wells. No portal axles raising the CoG up to high.
Blah blah blah, been there and done that nearly 20yrs ago now. I am feeling it as far as how capable this Cruiser will be. And I am feeling that it will eat up this Patrol build we did way back in the day! At least keep up with it! The Patrol had about 5ft of wheel travel but still, it’s not always about how much the suspension can travel.
We have a local rock crawling trail close to town here in Boise. I told Chris today who works for me, that’s the first place we are taking the Rocklander as soon as it is done and we are hitting all the hard lines day one!! 😂😁🤙
Cheers
Just a quick cardboard design to give me a basic shape to start working with before I cut out pieces of steel. I am going to more or less run it like this.
Cheers
Still at the shop! Just the bottom plate to make and weld in. I made the sides out of 3/16’s, the bottom will be 1/4”. I will probably fish plate the inner frame rail in this area with some 1/8 or 3/16 to strengthen where I notched it.
Cheers
Finishing this up right now, bit more to do but getting there. I would say this will take some rock hits and rock rash no problems.
Cheers
