Wanted Rocker oil line, F engine
Castle Rock, CO
Hello Everyone,
I'm in need of the oil line from the oil pump to the rocker for an F engine.
It's a little copper line with screw fittings on both ends. The lower fitting is on the passenger side under the side cover and the upper fitting connects to the middle of the valve rocker. See photos below.
rocker-oiler-01-jpg.765206
rocker-oiler-06-jpg.765183
This is the one courtesy of:
https://forum.ih8mud.com/threads/pre-start-priming-of-a-72-f-engine.741844/
Please let me know if you can help me out,
Thanks
-Justin
P.S. Not sure if 2F is the same and could be used on my F. Please chime in if you know.
The piece you are looking for is not on a 1974 F or any 2F engine.
It is only found on the 1973 and earlier F engines.
Aaahhh, very good to know,
Thank you
Anyone doing a V8 swap and getting rid of the old F (pre'74)
Still on the hunt!
I have an nOS one I will be putting up for sale in a couple of months. It will be part of a package deal with NOS rocker arm shafts, o-rings, head locator guide rings, rebuilt cylinder head and gaskets.
Still have any of these available? I'm in need of one! Thanks
If you have your old tube, SOR offers the copper line and ferrules for $27.00. I have used lines with the end fittings, but personally I’d rather spend a couple of extra minutes seating new ferrules on a new tube than straightening/modifying the kinks in a 50+year old tube.
Just ordered - thanks!
