I recently heard an intermittent sharp tick sound from the engine and stethoscoped it to the upper end. I tore off the rocker cover and found three of the exhaust adjuster screws worn half off on only one side. This made excessive clearance and caused the pushrod to make the tick sound intermittently. I ground the smashed portion of the adjuster and rounded it to fit back in the pushrod and then performed a valve adjustment. After the valve adjustment with the engine running and the rocker cover off the same three exhaust valves continued to wear and loosen the valve clearance. I also noticed that there was no oil squirting out of the holes on the rocker arms.
So, based on this, I have two questions:
First, where can I purchase replacement valve clearance adjuster screws?
Second, what is the normal amount of oil you see on the rocker arm squirting with the engine running? I seen no oil on the upper end squirting or sitting in the cast plugs. The oil pressure gauge on the dash reads normal oil pressure though.
Any help is appreciated.
Timing of this really sucked too, I planned on taking her to the beach and having some fun and camping.
Anyway, thanks for the input guys.
