Wanted Rock Warrior Wheels (5 Lug) TX
Texas
Looking for Rock Warrior Wheels. Toyota Part Number PTR45-34120 or PTR45-34070. Get Them out of your garage and lets make a deal :)
Texas
Thanks for the heads-up. It appears that those wheels are 6-lugs for the Tacoma. I'm looking for the 5-lug version for the Tundra/Land Cruiser. Appreciate you looking out for me. Have a great weekend
Last200
Henderson, NV
I'm confused by the two part numbers. Is there one that doesn't fit on a 200? I think the 45-34070 are the discontinued, so what's the 45-34120? Are they exactly the same specs?
Texas
Many (self included) had the same question. The answer is both part numbers fit the LC200. Here's a previous post by @gaijin explaining the difference: "The only difference is on the inside of the valve protection ring - the 34070's do not have drain cuts on the inside while the 34120's do. The PTR45-35110 rings - which have the drain cuts - can be purchased separately and retrofit on the 34070 wheels to make them just the same as the 34120 wheels. Here's a link to the later model trim rings: One Replacement Trim Ring for 17 TRD Wheel PTR45-35110" 17" TRD wheels
Alaska
I’ve been looking for a set for going on 3 years. There is a set of 4 currently on eBay cheaper then I’ve seen in a while, most of the time eBay has been ~$2500 for 4 and singles going for $600-$700. I’m having a hard time with that one considering I can get a new set of 5 methods for ~$1700
Last200
Henderson, NV
I just got five for 2,750. My local Toyota dealership ordered them straight from corporate.
Texas
Thanks so much for the lead, I'll have a look. Much appreciated
Clovis, CA
Not sure if you purchased as set yet, but if not, here's set in the Spokane WA area. Used, not mine.
California
I have a set of 4 with BFG K02s
I also have another set of 4 Wheels only, that are refinished in Yankee Gold and Black bead locker. They are unique, only 2 sets of them... and I have the other on my white 200 series.
Houston Texas
I have a set in houston with tires and sensors in good shape
