- Joined
- Jul 23, 2008
- Threads
- 69
- Messages
- 912
- Location
- OC, CA, USA, EARTH SECTOR-28
- Website
- www.tdubclub.com
RL1057 1F FENOM CARBURETOR INSULATION SPACER
Replaces the discontinued Toyota 12224-60060 Insulator, Carburetor Heat
Fits 9/69 – 12/74 F-Series Toyota gas engines.
It has been a long running issue with the stock Toyota 12224-60060 INSULATOR, CARBURETOR HEAT as they are prone to air leaks due to heat, age, bouncing around on dirt roads and/or us fiddling around with rebuilding the factory Toyota carburetors, cracking the tube while removing the hose. You’ve either seen or dealt with the issue if you’ve been working much on an 48+ year old FJ40 Land Cruiser, equipped with the 1F engine. We have a solution!
https://redlinelandcruisers.com/shop/40-series/engine/rl1057-1f-fenom-carburetor-insulation-spacer/
