Rio Puerco Run-- Sunday, 24JUNE2007?
Let's see the carnage Mike!
The rear sway bar is on the floor of the garage. You still want a pic? The left side factory bracket is broken. The Slee extension is OK. I plan to fix it and run with a sway bar though a quick disconnect (F&R) would be nice.
-Mike-
I had an OEM rear sway bar on the 60 briefly and frankly didn't notice a difference. What I did notice was the "crunch" when I tore it off on the waterfall on Poison Spider - not a good off road design.
I'm fairly convinced that the stiffness of most lift springs (leafs or coils) limit the body roll more than the OEM bars do.
-Mike-
You ought to be able to make up a set of QDs using parts from Ace. I experimented with QDing front/rear and then just the front and then just the rear. What I found it is that leaving the rear connected and the front Qd'ed forces the front to open more. So, the rears went from QD'ed to welded!
