Ride Height Geometry for AHC
Salt Lake City, UT
Should I drive in Low instead of Neutral?
I have a 2003 LX470 with AHC Suspension.
The previous owner also put in HD springs in the rear, BFG 285/75R16s, and a AHC override switch.
The tires are wearing unevenly in the rear only, wearing on the outside first. I guess I am wondering if the Low Geometry is closer to Factory and would help these tires wear more evenly.
No
1) Can you explain how AHC "Low" mode will change the suspension geometry, in order to change wear patterns on the rear tire, of a "solid" axle?
2) In "Low" mode, you're barely off the bump stops, I'd expect that it wouldn't ride all that well, and you're likely to "break s***" with that limited travel:
You should measure your height in Neutral and compare it to factory specs.
