Rhino Charge - this Pig went to war! (1 Viewer)
How about some pictures of the power steering install. When's the next race.
Keep up the good work!
i thought i had posted pics! obviously didnt attach.... here some now
the PSC hydraulic kit is pretty awesome and very comprehensive. The pump looks a bit small , so really hoping that the existing one i had for power steering will work.
built up a tray of some heavy plate and have welded that to the front portal axle. working on it still...
I love the work that has gone into this rig. What a franken cruiser! Cutting and pasting metal like it was frigging modelling clay.
Trying to score that carb kit for you here. Check your email. I found one.
so a few years on and a few more changes. Last year worked o n the geometry a bit more and got a more stable off roader. did this by moving the front axle as far forward as possible. in so doing the tall sump of the 2F engine satd BEHIND the diff tube and also lowered the engine a few inches. Moved the rear axle forward as well to give the same wheel base more or less, and maintained the unimog torsion tubes - which we cut and altered to size.
this resulted in a lower over all body height and better weight distribution, the engine and gear box being more centered.
Also the holley carb was performing below spec, and cutting off at steep angles. SO replaced this with the stock carb which worked great, at any incline.
However - I cooked the 2F engine at the last event, and with the BIG one coming up Rhino Charge 2014, the choice was to either bolt on a 3F which was available, and run it through the unimog gear box (which I also converted to 8 speed last year - 4 gears high ratio and 4 gears low)..... OR
get a V8 in there and put serious horse through the portal axles.
while at it, put in a more substantial suspension system, working with what we had available.....
the result: a UNILINK system with a TOYOTA V8 2 UZ FE engine, automatic gearbox, to run the portals and 42 inch tyres.
all in 5 weeks before the event. here goes.....
the idea was to make A frames to each axle hinged in the centre on the 'ball" of the unimog torsion tube.
This pig sits on a unimog 404 chassis - which gives it huge amounts of flex, the need to prevent axle wrap and breaking the propellors, housing, would be overcome by the A frames. the ball would allow any degree of rotation and up and down movement, the A frames prevent wrap.
so welded a chunky plate (from a truck chassis) at the centre of the chassis.
machined up a plate that was the same as the end of the gearbox housing on the unimog, for both sides, and mounted the cut off torsion tubes to this.
using 4 x 2 x 6mm sections and plate, made up the A frames. had to machine some flange adaptors for the diff pinion shafts, and bung an oil seal in there. used the TOYOTA propellors, though these would have to be cut to size...
for the front portal axle to line up with the TOYOTA gearbox, the diff had to be 'flipped' over to achieve this.
with the vehicle set on the bump stops we lowered the 2 UZ onto the chassis. the front propeller rake is steep, and a result of the flipped diff is the caster and camber is WAY out .... but, things lined up quite satisfactorily.
putting the body back on.... the 2F is a long and tall engine - the V8 squat : amazingly the cavity of the FJ55 happily accommodated the engine, radiator and all!
with the body on, there was the spaghetti of the wiring harness to figure out! fortunately the engine, harness, computer was a complete unit from a half cut 100 series TOYOTA...
built up the rear tray again.... cut out the panels of the FJ55 body and used those on a lighter frame, and aluminium floor. Used DOM pipe for the re worked roll cage.
assembled everything up, and had a test run. the transfer case was not in good shape, and the rake angle on the front prop shaft made for some interesting sounds, so played around with all that a great deal to get it right. time to test it and then fit the new bucket seats and clean up the interior.
some lipstick powder and paint..... and a fun test run. she runs SO BAD on road.... caster and camber is the next project...
on the trailer headed to the event. put her back on the trailer, pretty much intact.... after a really rough event. pleased with all the modifications. this is one tough pig.
Landmawe,
It sure looks like one tough pig! Do you have any more events this year? Did you get the steering figured out?
Is this thing a pig anymore? or a trangenic one. Great beast anyway. congrats..
