SmokingRocks
hopelessly addicted to Cruisers
I'm building a client's vehicle and he wanted an engine immobilizer installed but didn't want it to be one of the typical Cobra-style units. After searching around on amazon I found this RFID system. Since it was so cheap I bought 3 units. Once they arrived I ripped into one of the units to see if I could trust the build quality and I was decently impressed, they consist of a basic solid state logic board that ties into a simple relay triggered by the presence of the RFID fob within the vicinity. The biggest concern is how well the logic board holds up, but that's what a bypass switch is for.
So with the client's approval, I installed the unit on his rig and it works amazingly well for how simple it is. I intercepted the IGSW input into the ECU for the RFID Module to control and powered the module off the constant BATT and E1 ground source for the ECU. The beeper on the module was super abrasive so I cut that out and replaced it with a dash-mounted LED that blinks a warning sequence when the fob is no longer detected before shutting down. Lastly, I installed a hidden bypass switch that just reestablishes the original pathway of the IGSW circuit to the ECU in the event this thing craps out.
But as of now, I'm very impressed with this module. It's so simple and versatile that it could be set up for a ton of different uses, one that comes to mind is auto-unlock & auto-locking.
Here's the wiring diagram
My neighbor stopped in while I was in the middle of this and I'm pretty sure he thought I was making a bomb or something
