reversing springs for longer wheel base
in the garage
i am assuming that this will wack the geomatree(sp) on the axle/pinion angles.
my skyjacker springs look like they are 25"to center pin and 20" to center pin.
if i reverse the springs i should get another 10" of wheel base overall.
runnin spring under, will i have to re-perch the axles for pinion angles? and what happens with the steering geomatree( ;) ) can i go 5 more inches forward with stock 69 steering? looks like i should be able to(at a glance)
just gettin my ducks in a row :D
thanx in advance
jim
If you are going to re-place the perches and drivelines you may as well go SOA. You can rotate the rear pinion safely but the front is a different story. If you rotate the front you will mess up the castor. Most will say to cut and turn the knuckles. I'm in the middle of a SOA and I elected not to cut and turn at this time. Since I'm moving the Output flange back six inches (adding a Toy box) and the axle down six inches the geometry sholud work out. If not I'm getting a long splined front Drive line and can do the cut and turn later.
nope, no soa on the 40
want to keep it sua, and add wheelbase
this will be mainly a trail rig,so i'm keep'n it low.
thanx
jim
Jim, did you see my thread where I flipped my rear springs? I think I gained ~4 inches of wheelbase.
I did NOT think I needed to shim the rear axle to address pinion angle. If anything, I think it brings the angle back closer to stock after a lift w/ SUA...
Want me to slap an angle guage on there?
Oh, PS: I opted not to move my front axle out, but I would move it before PS. I am getting ready to start a 60 series PS conversion, and wanted to lift first so I knew where to mount the box.
As FJ Ben says:
FJBen said:
And we all know how important location is when box mountin ;)
I've done a bunch of SOA conversion using reversed springs and a couple of SUA rigs the same way. Sooo... the facts...
You gain about 4 inches of wheelbase at each end, not five. If you have a good arch left in the spring it may be a little less than 4. If you use shackles the same length as the FJ55 rear shackles (roughly an inch longer than stock FJ40 shacles) your caster angles will remian correct. Your factory steering will clear everything just fine, with the possible exception of the steering stabilizer frame mount. Cut it off and turn it around and everything is happy.
Mark...
Mark...
Mark, any experience with the rear pinion, w/ 4 inch SUA and flipped rear springs?
It looked like moving back on the spring arc brought the pinion back to vertical...
Do users typically lose articulation when flipping the spring pack on SUA?
I assume you also extended your DS? Did you put in a traction bar? Did you keep your shackle in stock position and the hanger?
I ran my 40 for a while with reversed stock springs.
Of course Mark is right. Flip the springs, 3.5ish" of WB increase (with stock springs it will vary a bit depending on which lift springs you use)
You will have to relocate the rear shock mounts.
You shoudl redo the front shock mounts for more available travel.
i know i'd have to do some drive shaft mods.
but with a sua, i dont think i'm gonna need a wrap bar with a sua.
2 1/2 lift springs will have a leaf removed in each pack.
shackels and mounts will stay in the stock locations for now.
4 link rear my be in the future :D
mornin mace ;)
totally agree, everthing will be changed as far as shock mount locations.
I forgot about rear shock mounts! I moved my mounts to the back of the crossmember, I'll have to post up some pics to finish my thread...
I also went w/ F-250 mounts up front and bought all new shocks at once.
The purpose of the longer shackle I mentioned is to retun the pinion angle/caster angle to original. If you don't do this the new position on the arc of the spring does throw these things off.
We've only done a couple (maybe 3-4) SUA rigs this way. I didn't notice the sprimngs being the limiting factor for articulation on these vehicles (shocks, bumpstops, sheetmetal and other factors came into play first).
You will want to trim the leading edge/outer corner of the front fender because the front tire will be moved forward to be directly under it. This will be the first point to interfere with articulation. Interfere a LOT.
Something else to consider. Many "lift" springs do a poor job of maintaining correct caster and pinion angle. They don't seem to give this much consideration when the make the springs. Caster shims and/or different length shackles may be needed regardless of whether you reverse the springs or not.
Mark...
Mark...
great info mark thanx
sheet metal will not be a problem ;)
mark w nice avitar got any stickers like that?
jim
i'm in the middle of doing this as we speak but i'm SOA with 2.5 inch lift springs, we decided to weld new shock mounts on then one thing led to another and now were in the middle of reversing my springs to gain an extra 3-4 inches of wheelbase, i'm currently at 97" so we should be pretty good, i'll post pics on how it goes and good luck with yours (2badfjs)
i'm not goin soa,but i think its a easy mod to do.i'm redoing the tub and sheet metal, so refabbing the shock mounts will all part of the plan..
