Return to center?
Discussion in '40- & 55-Series Tech' started by IDave, Aug 3, 2005.
  1. IDave
    IDave
    7,167
    Media:
    1
    Albums:
    1
    29
    Jan 3, 2003
    McCall, ID
    I've lately notice that the wheels FJ40 don't seem to want to return to center after a turn or a curve on the highway.
    I understand that this is mostly a function of castor, which is set by design at the factory and not adjustable, so I don't really understand why this is happening, unless there is something else I should be thinking of.
    No wrecks, checked the tire pressure (fine), knuckle lube. Even took off the accessory steering damper to see if that had anything to do with it. Nope.
    Am I missing something? I don't like the feeling that I'm gonna flip.
  2. lone gunman
    lone gunman
    1,400
    15
    Aug 17, 2003
    granite falls WA.
    how about your toe in adjustment? i went to LesSwab last weekend and they did mine for free it was off by 1.53% it drives a little better now and doesnt follow ruts as bad. just a thought good luck with it
  3. IDave
    IDave
    7,167
    Media:
    1
    Albums:
    1
    29
    Jan 3, 2003
    McCall, ID
    It's tracked pretty well for years, and I haven't changed anything. I guess I could check it, but I didn't think toe-in would affect centering.
  4. bad_religion_au
    bad_religion_au
    2,213
    2
    Apr 24, 2003
    have your springs sagged out??
    how are the bushings in the shackles and the solid mount of the front springs?
    shackles done up enough?
    bent a housing :|
    have you tried a replacement steering damper?
  5. sine80
    sine80
    607
    Media:
    1
    17
    Jun 19, 2005
    Tacoma, WA
    mines always been like that. :mad:
  6. 65swb45
    65swb45 Elder Statesman Supporting Vendor
    24,355
    9,366
    Apr 14, 2004
    818-953-9230
    First suspect-steering center arm shaft. Ease out the adjustment 1/4 turn and pump it full of grease, then drive it.
    Second suspect-knuckle bearing preload. Have to check this the standard way: steering rod disconnected and knuckle dust deflectors removed.
    Fun, Fun, Fun
    Of course it could just be low air pressure in the tires. ;p
  7. IDave
    IDave
    7,167
    Media:
    1
    Albums:
    1
    29
    Jan 3, 2003
    McCall, ID
    I think :) the springs/bushings/shackles look OK. The steering damper is a couple years old and the stocker in the stock position. Something to think about.
  8. IDave
    IDave
    7,167
    Media:
    1
    Albums:
    1
    29
    Jan 3, 2003
    McCall, ID
    Mark, the tire were at 30 psi, so that's out. I'll look at the steering center arm shaft next! Then, if I have to, knuckle bearing preload.
    Thanks! I HOPE its the center arm.
  9. IDave
    IDave
    7,167
    Media:
    1
    Albums:
    1
    29
    Jan 3, 2003
    McCall, ID
    Just ran out and did the centerarm adjust: road around the block, and it seems better already. I expect there'll be further impovement with use! :D :beer:
