Reproduction Instrument Cluster Meter Speedometer Barrel Connector Repair & Installation Kits (1 Viewer)
ToyotaMatt
Factory Focus-Point Mind-Set Approach
Supporting Vendor
GOLD Star
EAST COAST
Website
vintageteqparts.com
Looks good. Are the original plugs prone to failure?
They orientation key way get broken off by rough side ways pulling ,
also , PO,s like to cut them off and install a auto-meter gauge type cluster set up
if u can imagine it getting damaged by a PO that's the most likely cause , but they do break naturally also from UV rays and age / time use as well
You can also do later gauges into your early truck using these connectors without having to cut one off a good harness!
Awesome find Matt!
I worked with a Customs Company & had the original Black ones reproduced , :)
My only Complaint so far is They only could make White :mad:
I want Period Correct Color Keying :rolleyes:
Matt, Do you still have some of these available?
Yes i do ,
I hand make & custom taylor each Reproduction Barrel Connector Kit to My clients Vehical Spec's
Is that something I'm going to need for my Mod to the new Cluster, or is my Stock Barrel sufficient? Any reason to make a change? Just to have for a back-up? What do they cost?
Do u know the part # for the New Cluster meter u will be receiving ?
is it 83100-60180 ?
or another part #
double check please
83100-60180 Most definately
Saw that Fuse Box Service Spec. Connectors w/ Leeds - wires repair kit you posted. That is really sweet looking. Since you were going to send me some Terminals with the Fuse Box, any chance I can talk you into upgrading that to one of these Leads? I can email the Wiring Schematic.
Sure
Please call my shop to discuss further ,
also Your New Reproduction DATA plates Set and Restored 60011 headlight switch are finished and ready to ship out
Thanks
All that Choppin & Loppin Mess , is now Neat , Tight , Sharp , Honed Service spec. Pigtail's Ready for Connector to Terminals Bay
to mate with ..................:)
could you send one barrel connector & 10 brass clips by post to Sri Lanka ? Including postage, how much it wii cost ?
Due to the Complex Nature of Assembly , this Period Correct Reproduction
Parts Kit
Only Comes in Fully assembled Plug and Play Format .
YES , i DO ship international to Sri Lanka and beyond ........🌏
This is a Tech. Thread , so PM sent , respectfully ........... :)
kindly , matt
Fresh Period Correct examples of both 30A meter Early - 12/78
1/79- Later 50A amp meter
( Includes 3 pin pig tail in this Kit )
