Repost of a Repost (dieseling, etc..)
TJDIV
UP of MI.
Mod Emeritus
UP of Michigan
Website
www.roamwherever.com
Just reposting in hopes of sparking up new input;
Running Hot (on the exhaust side it seems...is that possible?...too rich, too lean??)
Diesels at shut off (There was A s*** LOAD of build up on the PLUGS)
Idle was at 1100 rpms, backed it off (timing) to 750 rpms...is that OK?)
I've got new plug wires (2 are bad) coming from Cruiser Dan so when they show up we'll rock n roll.
Give me your thoughts, experiences so that when this s*** comes in I can be ready to button this little job up.
Thanks People.... :cheers:
Mine did that when my idle solenoid went bad and wasn't shutting off the fuel. Was dumping tons of gas in and fouled everything. Also had a leaking intake gasket which eventually led to a burnt exhaust valve. The combination made for one helluva loud backfire. I would shut it off and hold my ears until it stopped dieseling and about 2 seconds after that would fire off. I'm still a little gunshy when I shut er down and walk out past the tail pipe.
Are those in order they came out?
Are the two that are black with carbon the ones with bad wires?
The build up is oil, I think. The tan plugs are a bit carbony, but not too bad. The black black ones are definately too rich.
Does your idle shut off solinoid work? I don't remember if you have an Aisen on that thing.
It does kinda look like you have a rich mixture from one problem and a lean from a different one. Might be two seperate issues like TRWs, might be someone compensated for a problem without fixing it.
Todd...
I've got DEFINITE compensation for an unfixed problem, I believe that.
They aren't in order though. There was significant build up on several (actually, ALL) of the plugs, the two that look more oily were 'tinkered' with by a stander by.
LOTS of build up. I have no idea about the IDLE Silenoid. Haven't checked it, don't know what it is or where (sorry).
Compensation came from the timing AND Carb. I think he may have adjusted the carb to run a higher RPM (more fuel) instead of compensating it through a combo of timing/carb/etc....
The Idle Shut Off silenoid....that is a definite possibility.
Any thoughts? Help is GREATLY appreciated.
You should have a wire running to a round solenoid on the carb. Power to it moves it, power off moves it. You should be able to hear it move/click when you get power to it. I've had three that broke the wire off right on the top, but it was still connected just not making contact so it was hidden. Had another just get stuck. Try that.
OK...TRW....that wire (WEBER CARB) looks to come right in on the side of the carb. Actually looks like it would be close to where a manual choke set up would exist on any other carb?
Either way, it looks fine, didn't "hear" anything strange...etc...
The idle cut off is ON the carb then...?
I should have this figured out by the weekend. I am, admittedly, better at paint and body work. Sheesh.
Thanks for the help.
Strangely enough, the Weber that came on my 45 was set high like that, too. I'd clean up the plugs, put them back in after regapping, and retune the Weber, before you go sending it off for a rebuild. Or, actually, I'd get an Aisen personally, but not because the Weber is necessarily sheit.
I agree that that hot wire is to the automatic choke.
Can you tell which Weber you have, Tom? It might not be the best one for your setup.
Weber changes things. No solenoid and the wire is to the electric choke. Webers are a pain in the ass to keep adjusted and seem to need to be adjusted constantly, or at least mine does. Check out the weber website, they have a great tech page on how to properly set up the carb and adjust everything. That's probably the problem. I couldn't get a 38/38 to ever run right on my F, runs much better with the 32/36 on there now but still needs to be rejetted. I'm probably going to get my old aisin rebuilt with a new solenoid and go back to it when I can aford it.
TJDIV, Im assuming if your running a weber its desmogged, you will probably want to look at a non-usa Aisin to run the vucuum advanced dizzy.. they go new for $750, you can probably find a rebuilt one for cheaper. If I remeber correctly the non-usa is a cable pull vs a linkage set-up so it would work well as a replacement for your cabled weber set-up. Good luck!
At SOR, rebuilt non-USA carbs are $450 or so.
Just a thought but make sure the butterfly/throttle plate is not open enough that the carb is pulling through the main circuit.
Since you say the idle speed is high this is definitly possible.
The idle speed screw needs to be backed off to drop the idle speed. If the idle mixture screw was re-adjusted it will be too lean and try to die. Bring the idle speed down as far as you can, at least down to 500rpm, then do final adjustment of the mixture.
If the throttle plate is open too far you will see fuel dripping down from the centering/aux venturies.
My Weber has a cutoff solenoid and manual choke. If yours has the solenoid it would be a fairly obvious cylinder ~3/4" thick and ~1.5" long screwed into the side of the carb, and a single wire with a female end connector on it.
Are you sure there is no vacuum leak and the carb is rich to try to compensate?
Good Luck!!
