Report from mechanic on new purchase LX450 150,900 miles
Discussion in '80-Series Tech' started by mreedbmwm3, Nov 13, 2017.
  1. mreedbmwm3
    mreedbmwm3
    326
    Media:
    3
    Albums:
    1
    629
    Jan 31, 2012
    Tulsa, OK
    Hi guys, man have y’all put the HG failure fear into my new purchase. LOL
    Dropped the LX yesterday and had compression tested:
    1. 200
    2. 198
    3. 191
    4. 188
    5. 190
    6. 190
    Going to do the following:
    New heater valve: $121.84
    Replace rear main seal: $857.30
    Replace air boot and other misc. parts: $295.65
    Replace seat motor: $371.61
    Needs new antenna mast :$225, going to hold off
    And New hood shocks: $109.94
    He worked at Lexus of Tulsa for a long time and he said he only saw one HG failure do to the guy having a cracked radiator.
    What are you guys seeing as the main culprit, and do you recommend any PM to address the potential issue?
    Cheers,
    Thanks
  2. Cruiser804
    Cruiser804 SILVER Star
    1,595
    Media:
    6
    Albums:
    1
    78
    Mar 11, 2006
    At the very least rebuild the front axle, replace the bearings etc.
    Irish Reiver and mreedbmwm3 like this.
  3. allan man
    allan man Since 2008 GOLD Star
    1,881
    768
    Mar 9, 2008
    Las Vegas,Nevada
    Make sure it aint the upper oil pan thats leaking before cracking open into the rear main seal
    Most of the times it aint the rear seal.
    76FJ40, LS1FJ40, DR71 and 4 others like this.
  4. bhicks
    bhicks Supporting Vendor
    3,512
    Media:
    8
    Albums:
    1
    1,218
    May 1, 2012
    Socal, Forest Falls
    Are you sure the seat motor is shot? Does it try to move but act like it's stuck? If so, the gear is probably shot on not the motor. It's a $15 part and about a 2 hour job to repair. There are plenty of threads on here about the seat repair.
    Desert Dino, mreedbmwm3 and mel lowe like this.
  5. Kernal
    Kernal
    6,097
    428
    Dec 10, 2007
    Rear leak is very likely not the rear main, but the main oil pan arch seal; do a search using those terms.
    DR71, mreedbmwm3 and baldilocks like this.
  6. Malleus
    Malleus
    1,543
    Media:
    13
    Albums:
    3
    810
    Jan 5, 2017
    Charlotte, North Carolina
    x2
    mreedbmwm3 likes this.
  7. inkpot
    inkpot SILVER Star
    12,106
    1,918
    Jan 30, 2003
    Chandler, Az.
    Heater valve is $40 ish at Rock Auto
    Izzyandsue and mreedbmwm3 like this.
  8. inkpot
    inkpot SILVER Star
    12,106
    1,918
    Jan 30, 2003
    Chandler, Az.
    Antennae mast is about the same from dealer
  9. mreedbmwm3
    mreedbmwm3
    326
    Media:
    3
    Albums:
    1
    629
    Jan 31, 2012
    Tulsa, OK
    Luckily this has been done.
  10. bicycleagent003
    bicycleagent003
    757
    Media:
    20
    Albums:
    2
    326
    Apr 9, 2013
    You could probably do a lot of that stuff if you're willing to spend some time on this forum and buy some tools. Not that you have to, but these trucks are spendy if you're paying someone else to work on it for you. Most people on this forum work on their own trucks.
    As for avoiding a HG failure, keep the motor cool. That means a new radiator cap, new thermostat, I would replace all the coolant hoses, including PHH, flush the entire cooling system (including the block drain plug on the DS of the motor), and if your radiator is original I'd just replace it. OEM parts are best for this stuff, though most use green Prestone rather than red Toyota coolant.
    I'd also recommend getting a Bluetooth OBD2 adaptor and using the free Torque app to get the actual coolant temp while driving. It's useful to know if you're running at 185-190 or already at 210.
    These are fun trucks, and this board is great. The search function will yield lots of tutorials on any of the subjects I listed here.
    Welcome.
    rc51kid and mreedbmwm3 like this.
  11. tominboise
    tominboise
    683
    Media:
    27
    Albums:
    1
    279
    Dec 17, 2004
    Boise, Idaho
    As mentioned I think 4 times on this thread, there are many places more likely to be leaking oil then the rear main. I'd start with the valve cover gasket and work my way down.
  12. LINUS
    LINUS Waiting for the Great Pumpkin
    3,889
    Media:
    10
    Albums:
    3
    1,823
    Mar 29, 2003
    PNW - WA
    HG seem to crap when a 80 is either swapped coolant poorly or they move to a cold climate from a relatively warmer area where that end of the motor never gave trouble before.
    Anymore since a HG is ~20% the purchase price of an 80, you might as well 'roll the dice' if you can, or get nutty if you wheel alone/out of cel coverage.
    More power to you if you get away not changing it.
  13. mreedbmwm3
    mreedbmwm3
    326
    Media:
    3
    Albums:
    1
    629
    Jan 31, 2012
    Tulsa, OK
    Hey thanks, BTW I’m rocking your emblem on my 200, bought it from you about a year ago!
  14. ajax1
    ajax1
    1,696
    751
    Feb 7, 2009
    Save yourself some money, replace heater valve on your own, all that stuff you listed can be changed on your own very easy, @beno can get ya parts way cheaper , if your worried bout head gasket change out all hoses and radiator keep fluid fresh , never over heat the truck , drive it I'm at 302k on original head gasket they don't go out as much as people say, don't buy into the mud madness
  15. mreedbmwm3
    mreedbmwm3
    326
    Media:
    3
    Albums:
    1
    629
    Jan 31, 2012
    Tulsa, OK
    Thanks, I really appreciate it!
  16. bakolc80
    bakolc80
    45
    3
    Jul 27, 2011
    Good advise above.
    Doesn't sound like he knows these trucks well. Have him check the PHH, that will absolutely leave you stranded and create a damaging overheat issue.
  17. shocktower
    shocktower
    1,014
    706
    May 20, 2009
    Canby Oregon
    I don't think he turns wrenches o_O
  18. mreedbmwm3
    mreedbmwm3
    326
    Media:
    3
    Albums:
    1
    629
    Jan 31, 2012
    Tulsa, OK
    LOL I've done my fair share. I'm just in a position that I don't have to today. When I was younger I had to learn to turn a wrench on my BMW. These days I'll turn one for fun. I'm super busy with wife, 6 kids, and work. I'm grateful for all the feedback I'm getting on here. Thanks guys!
  19. bhicks
    3,512
    Media:
    8
    Albums:
    1
    1,218
    May 1, 2012
    Socal, Forest Falls
    Can I use your pic on my website when I release the 200 series products next year?
    pengfinn and mreedbmwm3 like this.
  20. Desert Dino
    Desert Dino
    561
    683
    Jul 5, 2017
    Israel
