Replacing the manual steering gear box 1978 FJ40 (1 Viewer)
1978FJ40project
california
I am looking to swap out my manual steering gear box with a rebuilt one. Is it just a bolt off / bolt on situation? Or do I have to mess with detaching the entire steering column ? Not know, I am wondering if I unbolt at the rag joint and then there are 4 bolts that attach it to the frame ? But not sure if there is then play to remove it ? If I have to mess with steering column I am just going to have it done when I go to have the alignment checked ( I have an April appt at K&H in LA )
Jdc1
Akron, OH
Steering column isn’t hard to pull. The pitman arm can put up a fight. Are you going through the entire steering system? It’s well worth it to do upper drag link, TREs, center arm and knuckles.
1978FJ40project
california
I am going to let the mechanic do the more technical stuff... I’m not that skilled , just want to replace the steering box if it’s easy
1978FJ40project
california
Still wondering if anyone else has changed out just the steering box and was it just an unbolt / bolt easy switch ?
Engineer8000
Supporting Vendor
SOUTHPORT NC
Not fully familiar with your 78 but on my 73, its just removing the connection at the rag joint and the 4 box mounting bolts, after you disconnect from the pitman arm of course.
Engineer8000
Supporting Vendor
SOUTHPORT NC
Remove cotter pin, use wide screw driver to back out the end of the drag link then pop it off the pitman arm. Not too difficult. You may have trouble removing the pitman arm from the box , they can be hard to get off.
1978FJ40project
california
Got it .. the pitman arm to the box should just be thread over thread correct? Nothing to unbolt / unscrew ?
