ok I am going to go to Home depot today on my lunch break to get some studs, what exactly should I be getting? M8 fine thread? Sorry I forgot to grab a bolt before I left my house this morning.
Oh and my other question was, should I seal the gasket to the pan first or the block, I know people say the pan, but how do you know that the ring sections will fit into there seats correctly?
I put it on the block and made sure that everything was aligned and looked purdy from that point. that worked out best for me, but others may have a differing opinion.Make sure that the block is CLEAN and DRY! Put a thin layer on the mating surfaces and let it sort of dry so it gets tacky...while that is happening, stick some of the studs in around the block. Make sure everything is oriented in the direction you need so you can just shove it up there and not have to think too hard about wether or not everytihng is facing the right way. Also a good idea to have the bolts in arms reach as well as a socket etc.
Shove that motha up there over the studs that are guiding it.
It was at this point that I started the wrestling match with it....
I got one bolt started on the PS block(maybe 2 or 3 threads), then started trying to get one on the other side...I then used the force of my KNEE to push and hold everything in place and get a thread started on the DS of the block.
Swaring a lot helps grease the process...
Call it a "dirty whore", "MOTHER F*CKER" or other colorful sayings of you choosing....However, feel free to use mine liberally!
Also a good idea to have a beer near by!
Once you get those bolts started, sinch em up to where you can get the next ones in and make your way around the pan. Use an inch pound torque wrench to torque. Also, keep an eye on the integrtiy of the gasket. Im making it sound as if I being rather violent, but actually, I was being very careful not to crack the gasket.
I wish I could say it was very easy, but for me...it wasnt!
Youll have to go back every couple of weeks for the next few months of driving to re torque the bolts.
As far as the studs...I honestly dont recall the thread and size. I brought a bolt with me to be sure on size.
Good luck and post up how it goes!
Chicago
