replacing flange on front 3rd
cruiserjunktion
Cruiserjunktion@gmail.com
Supporting Vendor
GOLD Star
North Florida
I am swapping a 74 tranny/xfer into my 71. The swap includes dshafts and flanges. Swapped the rear, no problem. While swapping the front flange, I pushed the pinon back into the chunk. Since there is no removable cover on the front pumpkin, how do I fix this?
mel
BB
San Ramon, CA
Mel,
Where did you get your flanges for the swap? Getting ready to do this myself. Good luck with the pinion recovery....
Brian
cruiserjunktion
Supporting Vendor
GOLD Star
North Florida
Is there a bearing that has fallen?
ordered these flanges from $or
saleman had many many many different flanges........
I ordered flanges for a stock 12/74, since that is the yr of donor rig.
cruiserjunktion
Supporting Vendor
GOLD Star
North Florida
I pulled all the bolts out of the front 3rd member before reading any responses. I thought the 3rd would slide out, but it is held in some how.........
I want to dirtft..........
help
here
bolt third back and lock hubs , turn slowly , one way will suck it in and then jam , the other will try to force it back out but you will prolly need to stick your finger in and kinda wiggle the pinion to get it started if it jam already and make sure you hold it lined up , how far in it go ???? :confused:
cruiserjunktion
Supporting Vendor
GOLD Star
North Florida
the pinon is pushed all the way in..... resting in there sideways
3rd is ubbolted, but won't slide out.... if I pull the axle out a few inches,
do I need to rebuild the knuckles?
help
Wherever the truck stops!!
To pull the axles you will need to go into the front axle as far as removing the stub axles or spindles. So in answer to your question, yes, sort of. You will want to ensure you have all the spacers and are able to set the pinion bearing preload right.
It's time to pull out the shop manual.
cruiserjunktion
Supporting Vendor
GOLD Star
North Florida
here is where I am..... wheels, brakes, etc removed.........
next off is the brake caliper bracket. Once that is done what will I need to do next?
also,
besides 3rd member gasket, what else do I need to gather to complete this job?
I think you can leave the caliper bracket on (though the photo makes it look like the bracket might be welded to the spindle), but you must remove the 8 spindle bolts and take the spindle off. At this point, the birf will hang limply, and you can pull it out a little to clear the diff for removal.
After looking at the photo some more, it looks like maybe your caliper bracket is welded to a plate mounted on top of the spindle (in place of the dust shield that should be there). Anyway, remove the 8 bolts and the spindle (and caliper bracket plate, etc.) will come off and let you pull out the axles a little (or a lot, if you want).
cruiserjunktion
Supporting Vendor
GOLD Star
North Florida
bracket bolted on.......
the weld is part of the jto bracket....
goin to pull brackets and 8 bolts now
I'd get the gaskets as if you were doing a knuckle rebuild except for the felt one on the back of the knuckle as well as a new pinion seal since you need the seal out to install the spacers (they go behind the bearing. If you find any oil you may as well go all the way and rebuild since you're almost there anyways. Like I said, find ALL the spacers and replace them when you put the pinion back in. It'll mean a new pinion seal too. Install the pinion and spacers and check the preload BEFORE you install the seal. When all is well remove the pinion flange install the seal and put it together for the last time.
cruiserjunktion
Supporting Vendor
GOLD Star
North Florida
here is a peek inside......
grease looks like it may have some gear oil in it..... not too much but some....
does it need a rebuild?
No. Ogden, Utah
I surely would replace the seals in there while you're at it. Oh and the grease. Don't ya love these domino effect jobs. Sorry bro. So you got the 3rd out now right?
While you have everything apart, does everthing else feel tight. Trunnion bearings, hub bearings? Now's the time. ;)
cruiserjunktion
Supporting Vendor
GOLD Star
North Florida
3rds out......
I have a new 3rd gasket and pinon seal.
I ordered a knucle rebuild kit ........ should have all the seals
When holding the long axle, there is alot of play on the birfield. The short one isn't
as bad but gonna rebuild both....
How would you clean out the grease ? Should I clean the entire inside of the axle
housing?
