Well, most of the cooling system. I've been losing lots of coolant from a leaky radiator and/or failing water pump. No leakage from the weap hole, so I'm not so sure that it is the water pump. I see it drippping off the bottom corners of the radiator. Hoses are crap, but not leaking. But what makes me think it may be the water pump is that when I start her up and give it some gas, you can hear coolant circulating behind the dash, and that sound is consistant with engine speed. Does a failing water pump do that? Or is it something else...
So I am just going to replace the radiator, water pump, thermostat, and all of the hoses. While I am in there, what else should I do? Replace belts? Fuel pump? I would love not to have to dig into all of that stuff for a while. By the way, I've been reading the forums non-stop, and I can feel the confidence to work on this old gal myself building more and more. What a great resource, and I'm smokin' one for all of you fine folks.
