Replacing an AC Radiator
Hey sluff, first off why are you replacing the condensor (ac radiator)?
Just curious, was it diagnoised?
Special Tools: FSM (a must!) set of ac gauges/vacumn pump/ Air compressor/ac o-rings/freon
If this was diag. then you will need to:
1-vacumn the remaing freon from the system 1st
2-remove the condensor
3-replace any o-rings associated with the condensor fittings
4-replace the receiver dryer (any time opening the system replace this,
it removes moisture from the system so when you open the system you should replace this unit)
5-replace o-rings on the dryer fittings
6-pull a vacumn on the ac system-refer to the FSM for time & amount of vacumn
7-install freon into the system again
>during freon install check the sight glass (located DS inner fender) you will see foam first when installing freon, after 2nd/3rd can should get clear)
*after all is done check your vent temps with the AC blowing
GOOD LUCK!
Curious, also. Only 93/94 A/C condensor issues I've seen were leaking fluid on the right side near where the metal line attaches. A new O ring was the solution.
While the condensor is off, it would be a good idea to pressure wash the radiator fins with a degreaser before installing the new one.
DougM
I have to replace mine too. The PO's wife got backed in to and that was the only thing they hadn't replaced yet.
Dave
GOOD LUCK!
#4 is very important
:cheers:
Dave
Well this sucks. I didn't know I had to replace the dryer also at the time I ordered the condenser. The unit from AutoParts looks liek a perfect bet but I don't think they deliver to Russia. So I guess I will go for OEM option.
I had the system diagnosed and a small leak was found in the condenser body. I got the freon drained and now it's only the condenser and o-rings that I have to install.
The idea of washing the rad while the condenser if out rules. Thanks for the hint , Doug.
