Appreciate all the help from you guys! Have the air cleaner latches ordered! @mattressking thank you!
Does any have a good replacement for the rubber door trim that lines the front door openings? Believe they are discontinued parts numbered 62313-90A00-03 and 62101-90A00-03. The surround the cab door openings and go under the scuff plates at the bottom.
Mine are totally worn out -- wind and water easily pass through into the cab at the corners.
