fourlow&go
@ the speed of plaid
Having seen what's on the market for replacement panels, and dealing with used ones, from various sources, that may or may not be better than what you already have. I've decided to try and make my own, and I think I may be onto something.
While stamping would be the prefered method of reproducing these, that's just not feasible given R&D and tooling costs. So I'm coming at the problem from a different angle. Jig and weld.
The problem with that being, welding sheet metal, and heat distortion. My solution, 11ga / 1/8"
I hand made a set for my '73 40 several years ago and was very happy with how much abuse they could take grinding rocks. No sliders means more clearance, and the double boxed design held up surprisingly well. However, building them by hand was a lot of work and they didn't come out perfect. The next set I made by hand came out much better, and even worked with hard doors, but I always thought I could do better, maybe even produce a few.
Fast forward several years and I now have the time to bring new life into this project. I've invested the time into a jig, for adjustability, repeatability and keeping heat distortion to a minimum.
The boss is back, back to work. More later.
