I have a plugged front cat on our CA '97 40th Anniv. I started a post awhile back when the EGR rubber hose btwn the EGR valve and the EGR modulator popped off
https://forum.ih8mud.com/80-series-tech/681339-egr-hose-blows-off-plugged-catalytic-convertors.html
Does anyone have any current experience with aftermarket CA legal front and rear cat's for the '95 to '97 80's with the Y-Pipe???
I have done some searching and found the range of answers from 'just knock the innards out w a hammer and be done with it' to the single-cat solutions that seem to have problems throwing codes due to the possibility that the O2 sensors are not re-lcoated to the correct position to be able to read a single-cat installation.
https://forum.ih8mud.com/80-series-tech/174044-catalytic-converter-direct-fit-1997-califonia-vs-49-state.html
https://forum.ih8mud.com/80-series-tech/419666-confirm-can-one-universal-catalytic-converter-replace-dual-oem-setup-97-lx.html
https://forum.ih8mud.com/80-series-tech/334625-found-y-pipes-including-cat-214-shipped.html
The OEM route is ~ $2k! But its bolt on and I have gotten 16 yrs out of the OEM parts.
I ran across NKP Racing in TX:
http://www.nkpracing.com/storefront/index.php?main_page=product_info&products_id=345
They have a nice 304 Stl Stl Y-Pipe w a non-CA high flow front cat + rear car + adaptor pipe to connect to OEM rear exh in the $815 + frt price range. Looks like they have the nice weld jigs to produce the bolt-in solution, lifetime warranty, good customer service, etc. They can put a cats on the Y Pipe w the CARB cert (for CA) stamp on the cat for an extra $250.
They also offer a Y-Pipe solution with BOTH front and rear cats attached to it that will then let you connect up to their full exhaust and muffler package and still offer a tighter package than OEM near the slider frame bracket along with an over-the-frame exh pipe route. Very nice.
Sounds great but IF i need that CARB stamp on the cats to pass CA Bay Area smog checks, its close to OEM price with the obvious beneift of a better quality 304 Stl Stl (over the 400-series OEM Stl Stil).
Anyone have experience in CA with the NKP Racing passing smog and just using their non-CARB cat's??
Used from the wrecking yard is awfully tempting to just get the 80 back on the road for the wife tho its still $500 and they are at least 16 yrs old!! Who knows when a used one will fail.
