Replaced my Fan Clutch and WOW
Discussion in '80-Series Tech' started by john_eckels, Feb 25, 2007.
  1. john_eckels
    john_eckels
    700
    122
    Oct 30, 2006
    Columbus, OH
    Got a blue one from C-Dan at a nice discount, Thankyou. I figure that after 140K miles it might be a little worn and tired. Before changing , my engine was rather noisy when sitting at idle, sort of sounded line an ex gf's Pontiac Sunbird. Afer changing, very quiet. There is still a very slight noise which I am guessing is the AC idler. Finally, I recommend not to losen the alternator belts. I had to put a 22 mm socket on the alternator in order to hold the water pump in place to get one frozen nut off. Finally, I recommend purchasing a new set of nuts that fasten the fan to the clutch. Mine were rusted and I had to re-use them. Some PB Blaster cleand them up OK, but I wish I would have spent the extra $2 on some new nuts.
  2. podiev
    podiev
    420
    1
    Sep 24, 2006
    Philippines
    What is the part number for the fan cluth? How much from CDan?
    I'll be replacing my Alternator Belts / AC belt this weekend. Am thinking if the fan clutch is not that expensive, might as well replace it together with the belts.
  3. cruiserdan
    cruiserdan SupportingVendor Emeritus Moderator
    22,003
    5,793
    Mar 27, 2003
    Land Cruiser Heritage Museum broom closet
    16210-66020
    That number does not apply to the diesel vehicle listed in your sig line.
  4. dace voit
    dace voit
    279
    54
    Jan 25, 2007
    Winter Park, CO.
    Yeah, I know what you mean. I replaced my pulleys, belts and fan clutch at the same time. What a great improvement. The motor is so quiet now, especially when starting up from cold!
  5. landtank
    landtank SILVER Star
    19,063
    1,264
    Mar 27, 2003
    Groveland MA
    I'm not sure what you're referring to but usually after a fan clutch change start up from cold is notably louder as far as the fan is concerned.
  6. dace voit
    dace voit
    279
    54
    Jan 25, 2007
    Winter Park, CO.
    The noise from the fan blowing air is louder, yes. But the bearings were shot on the fan so they were grinding, hence the noise of which I meant.;)
  7. concretejungle
    concretejungle SILVER Star
    9,518
    743
    Oct 27, 2003
    North Cadillac
    gotcha. good to know. I have replaced my belts......was planning on replacing the fan clutch but after looking at it it is blue? I wonder if the PO replaced it? It still gives the loud roar when starting like it should, and i have no overheating issues, so i leave it be.
  8. DanKunz
    DanKunz SILVER Star
    9,709
    Media:
    2
    Albums:
    1
    1,006
    Feb 7, 2002
    Woodstock, GA
    I just put a blue on one this afternoon (Thanks CDan). I replaced the Hayden I was testing, which replaced my completely hosed stock one.
