Hi all,
About two months ago, I replaced the muffler and resonator (Northeastern stainless steel) on my 2000 lx470. I had a lot of trouble getting it to mount up properly, and am still not sure all the connections are seated 100%. After I replaced the muffler, I took the cruiser out and immediately got a code P0135, drivers side upstream O2 sensor. After determining that it wasn't critical, I made plans to replace later. Let the cruiser sit mostly unusued for 2 months or so, got lazy about changing out sensor, then used cruiser to haul a bunch of mulch in trailer (about 3000lb each time). The day after that, when driivng with family, notice shuddering, severe lack of power. Pull over, have the car towed back to the house, check codes and see P0303, misfire on Cylinder 3.
I'm wondering if I didn't install the muffler properly, causing the upstream o2 sensor to fail, which then caused the misfire. I am planning to replace the upstream o2 sensor, cylinder 3 coil pack and plug. Should I be looking at the exhaust system too? Should I make sure that is fixed before replacing the sensor and coil, or is it just coincidence that all this is happening at the same time?
Thanks in advance,
Thanks in advance,
