replaced intake and exhaust gaskets now it stumbles under low rpms? (1 Viewer)
wa
I had a large exhaust leak at the bottom of the intake at the heat riser plate so I put on new reflex gaskets. exhaust leak is gone
, idles good but a quick test drive and it sputters but I can accelerate out of it.
Any ideas ? timing? fuel filter? clogged carb?
forgot to mention it drove better before with the exhaust leaks.
Possible vacuum leak.
Time to get out the carb cleaner. Spray a little (a little!) in suspect areas.
Yes, this. If everything checks out, you may need to tinker with the carb a little. Might have been adjusted to compensate for a vacuum leak that you fixed
