Hey guys I need some help to understand why Beast wont turn over.
I've replaced the diesel injectors because one had a leak in it. I spent this morning putting it all back together again. The car sat apart for about 2 weeks while I found the correct injectors.
I've had the key on the accessories (not cranking) for 10 seconds at a time to prime the fuel. When I try to crank the engine it wont turn over.
Battery volts are sitting at 12.3. Theres power to the fuel cut-off solenoid. The fuel rails went on in the correct order and torqued to specs. The injectors were torqued to the correct specs.
I'm not sure what else I should try. I've read that there could be a need to take the fuel rails off one at a time and crank it til fuel comes out but i'm not sure how to go about this and cant find any information online about it.
